Your TA only needs to come up a little. For a plaster pool with manual chlorination TA should be 70-90. Adjust the TA to get in range and then adjust the pH as needed.
Not normally, most pools experience a slow rise in pHDoes ph go down over time? Does chlorine lower ph?
TomAtlanta said:Thanks for the info. I added more calcium yesterday and tested today. CH is now 170. I just added some more calcium which should bring it slightly over 200. I'll test everything tomorrow and post the numbers.
Is there any problem adding baking soda at the same time you add calcium and chlorine? If so I'll go ahead and add that today also.
Maybe I should ask a more general question so I don't repeatedly ask about this: is there any problem with adding any combination of chemicals at the same time, or can you just add whatever needs to be added all at once?
