- Nov 11, 2020
- 172
- Plaster
- Pentair Intellichlor IC-40
Hello all, I’ve been following the TFP method for almost 3 years now with great success after all the help to get started by many in this group. Other than the constant necessity to add acid, my pool is pretty low maintenance. My question is this: if I’m monitoring my cya levels is there any reason I should be wary of using Trichlor tablets during the winter instead of liquid once my SWG cuts off due to low water temp? My rationale is I’m constantly having to add more CYA year around due to all the rain here in Louisiana. So if I use Trichlor tablets instead of liquid chlorine, not only is it less frequent chlorine maintenance, but it also keeps my cya levels up until I switch my SWG back on in the spring. In theory, I’d be making a little less work for myself in the summer as well since I wouldn’t need to add quite as much cya as usual with the levels maintained over winter. Am I overlooking something?
