So its been a while, but we finaly have the liner in. I did not do it myself because i found a pool company that was willing to diagnose the watter line issue. I had 2 skimmers and 5 return lines. they had to cut into the wall to repair one of the returns that was broken right behind the wall, and completely block another return. Ihave 4 that still function... so i am happy. The water is still a little green. (a little better than in this pic) i shocked the pool per the liner installers instructions.... seems to be at about 18ppm for about 2 days now.....i have it covered, and its indoors so no sunlight. I am going to uncover it tonight hoping to get the chlorine levels back down..... Stabaliser is almost 0 and it is reading as 0 combined chlorine.
I seem to be loosing about 3/4 of an inch of watter a day.... so it looks like i get to play the game of find the leak as well... the liner installer did a pressure test on the lines and they are all good. He thinks its around the stairs so is going to come back tomorow with some dye..... If it is... we will have to drain it back down and try sealing it up again. Dont realy want to do that.. but i dont see what other options i have other than replace 500gallons of watter a day.
I also picked up a 200,000 btu propane heater for $200 on craigs list (10 years old hayward h200) that we are setting up outside temporarily until we can find a permanent place. ofcourse that needed a few parts... they are supposed to be in next week.
