I have an in-ground ganite pool, about 30k gallons. My TA is 50 (should be 60-120). How much baking soda do i need to use to raise it to the needed level?
Your best bet is to find the pool calculator in the pool school section here and learn how to use it. It will become your friend very quickly! I use it all the time
If you post a set of water test results and tell us how you chlorinate (liquid chlorine, SWG, trichlor tabs, etc ......) we can suggest a more specific TA level.
