My TA numbers have been rising for the past 3 seasons starting out at 120 and now it is 210. So i am going to go threw the process of lowering
with MA and aeration this weekend. I have a couple questions....
1. How long after adding the acid is it safe for use? or is the acid diluted enough that it wont be unsafe?
2. Is the aeration process something that i can work on a little every night, (with a pump from harbor freight and the kids splashing around) before shutting off the pump and putting on the solar cover for bedtime? Or will it require more constant attention?
