Hi,
My PB has setup the motorized solar 3 way valve using a 90 degree actuator instead of the normal 180 actuator. i.e. instead of the inlet being at the "bottom" of the T, it is coming in from the side. Hence the need to use a 90 actuator to switch between the outlets.
Is there anything wrong with doing it this way? In this case it was just because plumbing space was tight, and doing it at 90 worked better than the normal 180 layout.
Thanks
Thanks
