3 positions for Compool CVA 24
Aug 28, 2018
8
NH
Hopefully this has not been asked to many times. Can a Compool CVA 24 be programmed to have a middle position? Without losing the two end positions. I have an IntelliTouch. I am trying to make it so My deck jets and swim pad fountains can be run at the same time using the app.
Thanks for the help
I am not aware of any pool valves with more than 2 stops. They all have 3 wires, a common wire and then 24 volts is applied to one or the other of the hot wires which will make the motor turn in one of the directions. When the internal cam hits the dip switch, it breaks the power circuit and the motor stops.
Sorry for the double post, This is what you mean right? Makes sense. I moved the cam in the valve on the right so that I can run the sunpad blubbers, or sun pad bubblers with deck Jets, but I eliminated the ability to run the deck jets by themselves. Your way is better. I would also be able to adjust the cams in the valves to allow some leaking by so the features run at the right hieght/power (not sure the lingo on that). I will probably end up ripping out all the plumbing the pool installer did and redoing it this winter with a little thought and pride :) It could have been very clean it, is all hidden underground in a concrete "bunker" that holds all the pool equipment. No sound, keeps it warm for the spa in the winter, no weather, etc.
