Inside the controller, the voltage is converted into DC and then it is converted into digital 3-phase AC.
So, the voltage is DC inside the controller but the output is AC, which is what the motor uses.
Even if you have 3-phase available at your residence, which most people do not, you would still need the correct voltage and frequency.
So, it’s unlikely that you will be able to run the motor without a controller.
