ejs873
That is why you should have a contingency plan to drain the water from your pipes if you need. Since you said your equipment is in a shed, you will have a lot more wiggle room in terms of the rest of us.
I still argue you should not be running your heater, but if you do, just make sure it is on and stays on. If it cycles on and off is where you can have problems with the acidic condensation.
Is there a way to easily drain the water from the pipes above ground? I noticed when I open the lid on my pump to access the filter, all the water drains out of the pump... is it draining out of the pipes as well? I guess this would be different for each pool and if the pump is at the same level as the water
