- Apr 8, 2021
- 54
- Plaster
- Pentair Intellichlor IC-40
First question is regarding my spa. Do I have to get in and pick all the settlement out of the bottom of my spa by hand? There's gotta be an easier way?
Second question is regarding my steps and cabo deck. A lot of sand tends to settle up here. My pool cleaner doesn't make it more than a few inches up the curved bottom of my pool so obviously it isn't making it up the steps or onto the cabo deck. Do I have to just keep brushing that constantly? Shouldn't my filter handle this?
And my third question goes along with my second. It might be hard to see but the racer only goes up a few inches from the floor and while I am diligently brushing my tiles and walls it appears the walls are just slightly tinted a dirty color.
Now this is a brand new install and long story with my contractor and "pool startup" guy but the startup guy sorta screwed me and my contractor and at this point I just want to take care of it myself because I'm sick of people I don't know being in my backyard (project got started last October). It took almost 60 days from its first fill to get salt and some muriatic acid added to it to get levels somewhat reasonable. I've been reading a lot and getting barely up to speed thanks to TFP. So I guess I'm just looking for advice on what area I should tackle first and how to go about it. I brush the pools daily, sometimes 3 or 4 times (it's kinda therapeutic for me lol) The water is crystal clear (working on spa - finally learned about the 'spillway circuit)
I have a cheap 5-way test kit (yes @mguzzy - I AM ordering the TFTestKit) so I don't know my CYA level (assuming that means cyanuric acid?)
Most recent results for that (yesterday) is:
FC: 2.5 - 3 0
CC: 2.5 - 3.0
pH: 8.0
Alkalinity: 100ppm
I have a Pentair CCP520 filter (4 paper filters)and I cleaned those filters at about 40 days because it's a brand new build. (Another question there - it says it's suitable for fresh water pool only. Is a SWG pool considered fresh water?)
Running:
Intelliflo VSF pump (AT 1750RPM)
Intellichlor IC-40 SWG
Pentair Boost-rite pump for the Pentair Racer cleaner.
Auxiliary pump for separate waterfall
Oh, one more detail that might be important: the equipment pad is next to the house, approximately 5ft above the pool level (spa is level with equipment)
FC: 2.5 - 3 0
CC: 2.5 - 3.0
pH: 8.0
Alkalinity: 100ppm
Running:
