lbridges said:
It's possible not everyone looks at these new pool build threads.
Since the forum has gotten more popular and the posts are much more numerous, there aren't enough hours in the day to go through everyone. At least for me.
I think what has been suggested for the returns will certainly help to equalize the flow rate in the returns. But the way it is plumbed right now will not be all that bad either. The furthest return is on it's own leg which will help some to equalize the flow rate. It isn't all that critical to have equal flow rates out of the returns but if you give me the lengths of each leg, I can tell you what the overall balance of the plumbing is going to be. There might a simple change that will make both you and your PB happy.
But one thing I would insist on is using the same pipe diameter for the main drain. It looks like the PB downsized the pipe two sizes which there really should not be a reason to do that and many reasons not to do that.
Also, I can't tell but is the skimmer run a separate run and do you only have one skimmer?
