The electrical configuration: GFCI is in the main panel, non-fusible breaker located near spa. The GFCI is wired correctly (common from spa into the GFCI, pigtail into common bus bar). SPA is connected to the sub-panel. Sub-panel connects red, black and ground together, common is wired with wire nut.
The spa operated properly initially for 10 minutes. The GFCI tripped and now trips immediately.
