Hi. Me again, I have written before about how to decrease alkalinity without effecting pH. I have not tried to do this yet, but have other problems because algae is starting to grow in the pool. I think that i am just keeping it at bay. The total free chlorine is fine in the pool but the combined chlorine is very high. i have read that superchlorination will help this ratio and help with the algae problem. But if you don't calculate the amount of chlorine to add just right it could make matters worse. I have also read that you can do supershock with non-chlorine products that will help in the sense that you are not adding more chlorine to the pool. I am so confused i just want to empty the pool and start over, but eventually the same thing will happen so i better figure it out now. I have the numbers available for the chemistry of the pool. any advice would be helpful!! thanks
Saturation index- balanced
Total dissolved solids 100
free chlorine .1 (low)
total chlorine 1.1
combined chlorine 1 (high)
pH 7.7
Cyanuric acid 12 (low)
Copper, Iron, calcium (OK)
Total and adjusted alkalinity 193 (high)
