2024 Hurricane Season is Here
Texas Splash
52,069
Fiberglass
CircuPool RJ-45 Plus
And so it begins. Previous links and related discussion provided below. Refer to that info and you should be fine. Be safe.
Katy, TX is in direct path. At 9:05am the eye is passing over.
Had to drain 5 inches or so from pool as nearly overflowing the coping.
Have some big limbs broken off from neighbor's house. Pool is full of small debris of leaves and twigs.
Will start cleanup after this whole Hurricane Beryl passes over us.
Yeah, my earlier post was way off...forecast updates kept pushing Beryl's track eastward and it's currently pretty much directly passing over Katy and West Houston.
No power since 6am, pool and yard are full of leaves and branches, and it's still too windy to go outside and start generator. Good times...
Reactions: HermanTX
Lessons Learned and Best Practices (hopefully)
Prior to storm, ensured FC was on high side using SWCG and LC. Also ensured pH was in low 7’s. CH, TA, CYA, SALT all set as before.
Set SWCG at 90% to create some added insurance as I knew would need to drain some water. Due to high heat conditions before the storm, the pool water evaporated and I let it go down to bottom of skimmer inlet and ensured main drain was full open. No sense adding water when the storm would bring plenty. There is no auto fill or auto drain on the pool.
Day of storm, Started about 3am. Just at daybreak the coping was starting to be over flowed (my rain gauge read 5 inches but my weather station reported over 6 inches). Still had power so weathered the storm and drained pool back down to skimmer inlet.
About 2.5 hrs later, as eye was passing over, pool had filled to almost the level of coping. So drained again. This was easier as virtually no wind and rain in the eye of the storm.
Did a quick test and chlorine level was still in range, but added 1 gal of LC plus 3 pucks in a floater as insurance knowing my CYA was dropping as well with the water draining.
Thought I had managed this well then at 11:20am the power went out. Did a quick test and FC level was definitely on high side but did not test CYA but knew that was lower then where I started the day before. I let the pool sit idle hoping power outage would be short duration.
Got busy packing Yeti ice chest with fridge stuff. I had purchased ice the day before so ready for use with the Yeti if needed.
Packed another with frozen foods. Stayed night with friends who had power.
Next day (1st day after storm), power still out, however Pinch A Penny was open - cash purchases only. Bought 5 gals of LC. I should have purchased this 2 days before the storm but forgot. Current levels all good so did not add any MA or LC. Hoping power to come on.
2nd day after storm - still no power - Put in some LC and also put in the Betta surface skimmer and the Aiper S1 bottom cleaner. I had charged both the day before the storm hit.
Ran both bots to clean what they could and also stir the water as added LC and acid throughout the day and doing spot checks of levels as I was scooping up big debris.
About 60 hrs of no power, the power returned. We are the fortunate ones as many to the east of us who had the brunt of the storm is still without power. Checked SWCG and turned it down as still plenty of chlorine.
3rd day after storm - had power so pump running and tests values were OK. Low CYA, Low CH and Low Salt as expected.
Ran bottom vacuum again (the Betta surface skimmer stays in pool full time) and added stabilizer to increase CYA. next will be CH and SALT adjustments. Also did a backwash on the DE filter just to remove any crud from the time pump was running during the storm.
Definitely no algae and the bots did a great job on the debris after I removed the large items.
I was relatively lucky, all things considered.
Before the storm, water level was normal and chemicals were balanced, salt at 3300ppm, chlorine intentionally on the high side (~7ppm).
Experienced ~6 hours of high winds and basically nonstop rain. Nearest gage showed 9" rain total. Impressively, the pool never overflowed - overflow drain did its job.
Lost power at 6am Monday, but surprisingly - we got it back by 11:30 on Monday (side note - 5 days later, half of our street is STILL without power).
Checked on pool as soon as power was back. It was already so cloudy that I could barely see the deep end drains. I checked water, FC was down to ~1ppm and salt was down to 2500ppm.
Turned on pump, filled three trash cans with leaves and branches, added two bags of cal hypo shock and three sacks of salt, set salt cell to 100% output and ran pump overnight.
By the next morning, pool looked great! I had ordered algaecide/clarifier but won't need to use it yet.
The pool has been a huge blessing in the aftermath of the storm. We're hosting friends who still don't have power and their kids are swimming every day and having a great time. I've enjoyed jumping in myself after evenings spent cleaning up storm debris.
Yeah this was the one mistake I made when I had the pool built. The pool company convinced me that I would not need an overflow drain and that it would not be worth the price. However 3 years later and understanding that without power you cannot drain the pool, I wish I would of had them put one in. Now it is just an inconvenience since I hook the pump to the generator during powerloss and pump it out that way. If I had to do it again, I would have that overflow drain.
I had been out in the rain at 2am too many times with the old pool to know I needed a drain with the new one. And for ~$200 it was nothing compared to the cost of the pool.
If can get one end of a hose lower then the desired pool level a garden hose can be used as a siphon that will work without power.
And like general supplies it’s a good idea to keep some salt on hand during the storm season. We had a big rain event a couple of years ago that wiped out our salt supplies for months.
Just as an idea, I live in Miami,FL and deal with heavy rains all the time, When my pool was constructed i asked them to add a additaionl port to the side of the pool which i later plumbed to the side of my home and made it a auto drain.
I told my friend what i did and i helped him before the storm with a 1 inch hose at the bottom of the pool to his fence which we zipped tied at the level it would over flow and maintain the waterlevel.
Reactions: HermanTX
Question about the linked article about flooding. It mentions watching if the overflow gets overwhelmed and the water is lapping the coping. Is this for all pool surfaces (I could see vinyl being critical for this)? In a pebble pool what would be the harm (just so I better understand) if the water just flowed over the top?
Could you further explain how you did this, any pics?
