Will you be adding new 4x4s to sit on the block? On grade=on ground-my learn for today! THANKS! That is what I thought but wanted to make sure!
Kim
Kim
Kim
I had to fix deck footing like that once on edge of deck, used an auger on the skidsteer and made the hole 18" but deeper. used the shovel to knock down deck side of hole so footing would grab a post and used post digger to clean hole and made footing oval, left it low on yard side to cover w landscaping/dirt, but your footing may be inbound of edge. Maybe you could pull a few boards and go thru that way, or just do a slab on grade and adjust as it moves thru the cycles like alaskans do
I was going to ask if you had any idea how much heating it would cost you. Guess that is a yes you do know! LOL
That water looks awesome! Well done sir!
Kim
Chris - I’ve been busy...
But love that faceplate... whoddathunkit?
The install is universal and there is no relation to the SWG. The water supply is fed thru return lines so you do not need to worry about the SWG flow switch triggering.
For a really small pool like mine, I believe this is an important feature. It wouldn't take too many cannonballs yo get water below skimmer and fry a pump.
Price was $569 Canadian. Around $400 USD I bet.
I have adjusted half my returns to pull from the main drain to take care of this problem
