We have a Lochinvar ERN252 that was installed by the house's previous owner right before they listed the house for sale. (It's six weeks outside the 2 year full warranty, but still within the three year heat exchanger-only warranty) We went on vacation two weeks ago, and when we got home we noticed that the pool was low. The next day, I noticed water leaking out of the heater. I removed the top and front covers and found water leaking out of the burner tubes. Not good.
So I called Lochinvar, and they referred me to a local dealer. They were able to come out that afternoon to troubleshoot it. We opened up the combustion chamber, and found an obvious leak in the heat exchanger (there is a hole in the last return tube, and not a small one!)
Long story short, the repairman contacted Lochinvar, and sent me a quote. If I front the $1900 for the new heat exchanger, we can send the old one back and they will evaluate it to see if they will warranty it. The total quote worked out to $3500!! (Plus the $170 I already have into it for the call out. He included new temp sensors, ignotor, flame sensor, bypass valve, and gaskets.) At most, I *might* fet the $1900 nack from the heat exchanger if, and only if, Lochinvar seems it a warrantable failure. I'm still on the hook for the $200 to ship the old one to them and the new one back.
(By comparison, he quoted $3000 new, plus $1000 for installation. I about fell over! Installation? It's three wires and a gas line! No plumbing involved! If it takes an hour, something's wrong!)
I pulled the heat exchanger myself, and disassembled the manifold. It looks defective to me, not a freeze issue (which I already knew. I drain it, then suck it out with a shop vac to be sure it's dry).
Shopping around, I could replace the heat exchanger for about $1200 and buy the $35 "gasket" from the local o-ring supplier for about $7. If I spend the hundred bucks to ship it back, it may be throwing good money after bad if they won't warranty it. Is it worth it to try and rebuild Humpty Dumpty under warranty? This unit brand new is about 2 grand delivered (online), and I would have a pile of spare parts. (Basically everything but the heat exchanger) I could also ditch the Lochinvar for a Raypak or Hayward for about the same price... I've even considered silver soldering the heat exchanger to buy me a few more years, but I don't have a lot of confidence in Lochinvar if this thing only made it two years to start with...
So, what do the experts say? Take a chance on the warranty? Repair it myself? Dump it for a new one?
Thanks, gang!
GIJoeCam
Thanks, gang!
GIJoeCam
