Hello TFP,
We just bought a pool and it will be my first time ever trying to take care of one. I found this forum a little late as I may have already been 'pool stored' but the more I learn now will make it easier for next year. My pool store sold me on EZ Pool for "once a week maintenance", a Nature2 to "cut the amount of EZ pool used in half" - AKA saving $220 worth of EZ pool (so about $100 savings after the price of the Nature2) along with some 3 inch chlorine tablets and quick shock (which I plan to use today to open the pool). I am learning a lot about the BBB method that I wish I knew sooner and have a Taylor K2006 test kit arriving today. I know the forum, in general, is not a fan of the Nature2, but for my first year I may end up using it along side EZ pool as I do not have as much time this year to dedicate to pool maintenance and want to try to learn more about BBB and pool chemistry before I jump in. The reason I decided to post on the forum now is I am just looking for general thoughts/advice/warnings/words from the wise on the items my pool store sold me. Does anyone else use these chemicals or should I be hunting for a different brand? Did I get 'pool stored'?
Current Chemicals:
EZ Pool Concentrated Pool Blend - $220 - 20LBS
1.6% Copper Sulfate Pentahydrate (.4% metallic Copper Equivalent)
98.4% OTHER
ProTeam 3 Inch High Tech Tabs (chlorine Tabs) - $77.25 - 16 LBS
91.5% Trichloro-s-triazinetrione
5% Disodium Biborate Pentahydrate
3.5% OTHER
ProTeam Quick Shock - $19.50 - 3 LBS
99% Sodium Dichloro-s-triazinetrione, dihydrate
1% Other
Nature2 Cartridge
Listing this under chemicals to paint a full picture
The instructions I was given - predilute the shock in a 5 gallon bucket with warm water - add water first then shock - one bag per bucket (the shock is in three 1LB bags) and then add to pool. The next day add 6 scoops of EZ Pool and 3 chlorine tabs. Was told to keep pump running 24/7 for the first 3-4 days. After this startup process I was told 2 scoops of EZ pool per week and 3 tablets per week as a baseline. The pool folks are saying this is the preferred method for over 3k of their customers, and to be fair I do know other people who have had good experiences with this pool store and also use the products I listed above, but I am not someone who just blindly listens to advice without doing some of my own research. One other item of conflict I have is that I was told putting the chlorine tablets directly into the skimmer was just fine, but nearly all digging online shows this could have adverse effects on the pump and filter, so I bought a floater to play is safe.
I am also looking for advice on how often to run the pump. From my calculations the pump I have should be able to do a full circulation of water every 4.5 hours. I am learning as temps rise, pumps need to be on more vs lower temps, less pump, but at a minimum you should at least circulate your water 1 full cycle per day. I just bought an outdoor smart plug to assist in this process and am looking at ways to write some IFTTT logic using weather as a guide to help automate pump activity - does anyone have experience doing this with success? Any other pump related advice is also welcome!!
I added pool details in my signature but if there are any other details needed to provide advise or suggestions please let me know and I will post the details.
*Admin* - If I posted in the wrong section of the forum please forgive me and let me know where to move my post.
Thanks!!
Current Chemicals:
98.4% OTHER
3.5% OTHER
1% Other
Nature2 Cartridge
Thanks!!
