- Oct 25, 2015
- 5,200
- Plaster
- CircuPool RJ-60 Plus
Dan,
Welcome to TFP!
First a couple of questions. Why are you slamming? What test kit are you using? Be sure you've read and understand the SLAM process before you start. If you haven't already done so read this link and ask any questions you may have. Based on your description your pH is very low you need to raise the pH as soon as possible. CYA is acidic so don't do that first. Even though you have a vinyl pool pH in your range will damage equipment. Use Soda Ash per instructions and aeration.
Please also add your information in the Signature. Click on your screen name above right then click again on "signature" and fill in the box then press "save". This will save a cycle of questions when you ask for advice. Information like pool size, type, pump and other equipment brands plus model numbers are extremely helpful.
I hope this helps.
Chris
Welcome to TFP!
I hope this helps.
Chris
