I just closed my pool for the first time and would like to make sure I did it correctly. I’ve read the forum posts regarding blowing out the lines but as you’re aware, every pool is different!
After making sure the pool was clean and ph and chlorine were at the correct levels, I drained the pool below the skimmer and returns. Then I hooked up the Cyclone blower to the skimmer return port. I blew the 5 returns I have and closed the return valve. I’m thinking now the air can only go out the floor drain so with the return valve in the middle position (normally pulling from the skimmer and the floor drains) I kept the blower going.
After the floor drains were bubbling for a few minutes, I turned the valve to the skimmer position, ultimately closing the floor drain. At this point there was no where for the air to go so I turned the return valve to the fully closed position - I believe locking the drains and skimmer completely.
My question is: was that the correct procedure? I’m a little nervous as I know frozen pipes would cost thousands to repair. Closing a pool doesn’t seem like rocket science and with all the info in this forum, I figured I’d try it to start saving $400 a year. After the cyclone purchase, I’m still ahead. Just want to make sure I did everything correctly.
Thanks in advance for any replies!
