@HermanTX @TampaKathy
So after sending a slew of pictures and emails to the builder, when the PB project manager stopped by I let him do all his measuring. he was checking every aspect of it. After I saw he had a break in the work he was doing i went out there to discuss what's going on.
He told me what is throwing it off in some ways is an optical illusion with the raised beams, paired with my understanding that the waterline is 3" above the tile bottom, and the waterline being 6" high. So here are the things that are leading to this.
1. The waterline tile that was used to start the main line is just our 12x24" tile cut in half. He stated that these tiles are what they call nominal tiles and they are not a full 12" so when they cut them in half it's actually 5" and something. So naturally all of the tiles are slightly higher than 6" from the coping.
2. The designer uses the 3" above the bottom of the tile as an estimate. The waterline is going to be determined by the overflow drain and where they are expecting it to be. It will actually be only 1.5-2" above the bottom of our tile and not the full 3" which brings down the waterline in the skimmer.
3. He is bring the level out tomorrow to double check and show me that it's level, if it is level like he says than the waterline being right for the skimmer on the sun shelf wherever that is will be the same for the other skimmer and work properly.
Essentially I kept hard measuring the tile to 3" waterline as well as not factoring in the tiles are actually smaller than the 6" or 12" full tile. He showed me a couple other 6" raised beam skimmers they are working on now and they look like mine, only difference is they need to float that bottom up a lot more on mine.
I guess we will see when it's all said and done but I will let you know what the verdict is when he brings out the Transit Level as he stated to show everything lines up and the issue is more the idea of me thinking the tile size etc. He kept assuring me and adamant that both the skimmers are absolutely level cause he checked a million times. The botto not being floated up on the skimmer and the raised bar are causing me to see it a different way. Let's see.
We have a break in the weather so they are getting the ground ready to do the deck and stepping pad forms at the moment.
