I'm replacing a motor that was a 1hp/1.5sf w/ a 1.5hp/1.0sf (same difference right?) ..but noticed it had a 1hp impeller mounted to it from previous install before. This will work right? Just move less water gpm. I know you can't go the other way..bigger impeller on smaller hp motor since it will burn it up. I would just slap a 1.5hp impeller on to match the motor but fear I'd have to change out to the diffuser and possibly other parts as well? Thank you in advance for any help!
