Welcome to TFP!
That pump is very likely to be fine with that filter, but it depends on the number number of gallons per minute you are planning for, which in turn depends on quite a number of factors. If you tell us more about your pool, number of gallons, number of skimmers/returns, any water features you are planning, spa?, and so on we can give you a better idea.
Generally speaking you want the smallest pump you can get away with, to save on long term electric costs, and the largest filter you can afford, to minimize the frequency of filter maintinance. If you don't have any water features a 3/4 HP pump would probably be plenty. Also, saying 1 HP doesn't really tell us much as different 1 HP pumps move quite different amounts of water.
