Results 1 to 11 of 11
Thread: Pictures of my backyard and pool
    Mar 2010
    Spring, TX
    1,082
    Here are pics of the backyard. Still working on the yard not the pool.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Mar 2010
    Spring, TX
    1,082
    Re: Pictures of my backyard and pool
    More pictures
    Feb 2008
    Denton, TX
    5,061
    Beautiful!
    Nov 2009
    Indialantic, FL
    323
    "Still working on it"...I presume this means the yard, 'cause the pool looks lovely!
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by 257WbyMag
    Beautiful!
    That last pic on the left where you see all the dirt by the fence. We are thinking about putting cement down there so we can put chairs around the pool. Right now there is not any room right around the pool for chairs without being right by the pool.
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by lbridges
    Yes you are correct. Made that edit in the first post.
    Butterfly's Avatar
    South Carolina
    10,045
    Beautiful! Good work!
    You're done SLAMing when:
    FinsUp's Avatar
    Jul 2009
    Michigan
    68
    I sure wouldn't hesitate to add more concrete. When we had the concrete pour around our pool last year the contractor mentioned it was probably the 2nd most concrete he'd ever poured around a pool. It looked massive at first, but once we loaded it up with pool furniture it "disappeared" rather quickly.
    32.6K Gallon 16x41x24 L-Shape Vinyl Inground by Fort Wayne Pools
    DE Filter, 1HP Pump, Sta-Rite 400,000 Btu Propane Heater, Pentair IC40 SWG
    One Wife - Three Kids - Two Dogs
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by FinsUp
    Any pictures of the before and after or just the after?
    FinsUp's Avatar
    Jul 2009
    Michigan
    68
    Any pictures of the before and after or just the after?[/quote]
    I guess just the "after" because it was a brand new build from start to finish. The "before" was a really sorry excuse for grass in Michigan. I've still posted a couple of pictures though. These were from around Labor Day weekend 2009 and so there was and is still some work going on. The DW will be adding lots of container plantings to the long run of steps to break them up, as well as scattering a few around the perimeter I'm sure. Also, I'm working on planting grass in the area to the left of the cabana as well as repairing and re-planting the areas outside the fence that were damaged during the build.
    Mar 2010
    Spring, TX
    1,082
    That is a nice pool fins. Looks great.
