Thread: Spa wall tile falling off
    May 2008
    Hockessin, Delaware
    48
    I have a 4 year old Gunite Pool. Every year when i take my cover off the tile on the spa wall on the pool side are off and in the pool. I call the pool company and they send someone out to reintall and regrout the tiles. Can anyone tell me why this might keep happening ?
    21 X 42 freeform gunite pool w/ spa
    white plaster finish
    Jandy VS ProFlow Pump
    3 returns, 2 skimmers
    pentair DE filter
    Aquapure 1400 SWG
    Raypac 399,000 BTU Heater
    Zodiac Nature 2 Pool sanitizer (haven't used yet)
    Guest
    Re: Spa wall tile falling off
    Cheap thinset material. Poor workmanship. Poor surface prep.
    No reason for tile to fall off unless it has been improperly installed.
    Apr 2010
    7
    Quote Originally Posted by simicrintz
    +1 on that
    One reason that tile fall off for is the same reason you get cracks in your driveway when it freezes moisture gets behind the tile, freezes, expands and pushes it out. You can possibly lower the water level in your spa to a couple inches under the tile and see if that helps. But simicrintz just about hit the nail on the head
    16K IG Plaster Pool w/ Hayward 36sq.ft. DE filter I'll have to add the pump info when I can get to it.
    Testing with TF-100!!
    Guest
    Just noticed that Nature 2 system in your signature! Saw you haven't used it yet. Go ahead and write that in to your ad on eBay and get that thing away from your pool
