Hello,
I have been studying the CYA-chlorine relationship chart provided by Chem Geek et al. This is a well thought out analysis and the chemistry seems correct. But, no surprise, it brings into question recommended industry standards (at least in my case). We have a small (2400gal) outdoor vinyl exercise pool. Recommended FC levels by the manuf. Are .5 to 1.5ppm. and CYA 20-50. Possibly they are at the lower level because of perceived vinyl liner problems if chlorine levels are too high. An article on vinyl basics in Pool and Spa News lists 1-4 ppm as a guideline. This at least puts Chem Geek’s suggested level of 4-6 ppm with CYA of 30 almost within reason (my CYA is 35).
But, on the face of it, the charts also seem to go against other opinions given here that the goal is to keep chlorine levels as low as possible but still be effective. Nice to say but, other than no one getting sick, how to measure effectiveness? ORP readings, which I’ve made, are not well thought of here by many (perhaps because they’re difficult to make) but were a main measurement of a water filtration company I worked for that sold commercial fish tanks.
When I started taking care of the pool CYA was 20 and I later bumped it up to stabilize things during the day when the cover was open. I also see that CYA of 20 is not recommended per the chart. But, all things being equal (Ph, temp, etc.) ORP is also affected by CYA being lower as CYA goes up. I’m thinking that after our next water change I’m going to keep CYA around 10 or 20 and monitor chlorine more frequently keeping it at the 1-1.5 ppm level.
What levels of chlorine do those of you with vinyl pools strive to maintain?
jvf
jvf
