I'm trying to get my greenish pool clean after neglecting it for a bit. Had a test done that showed my FC and CYA are almost zero and high pH.
FC 0.08
CC 0.28
pH 8.1
TA 98
CYA 4
CH 288
Salt 3904
So need to raise FC (to shock level) & CYA, and lower pH. I was thinking of using Dichlor i already have to do this.
Using Pool Math, adding 1700g of Dichlor will raise FC by 24, raise CYA by 21, lower pH by 0.9, and raise Salt by 19.
Is this a good idea as a starting point? I realise i will later have to balance it including raising CYA to 30 (with acid) and maintaining FC shock levels (with bleach).
Also, should i be concerned about my high salt level?
FC 0.08
CC 0.28
pH 8.1
TA 98
CYA 4
CH 288
Salt 3904
