I have a fully hayward system that is automated and has been working fine. Recently I noticed the pump was still running outside of the timer setting. The system showed the
pump was off but it wasn't. It wouldn't respond to the on/off button so I selected the service mode which should turn off everything, but the pump kept running. Only way to
shut off the pump is with the breaker. Any ideas of where the problem might be. I also just replaced the circuit board because of a no cell power 2 issue however the
pump problem started before the board change and continued just the same after. Thanks.
