So glad you have a concrete reason for the “loss.” Congratulations!
And just to reiterate, though you’ve probably got it now, you need to add your final dose, let it mix for 30 minutes, and TEST AGAIN! You have to have that starting number for the OCLT from your test kit, not from pool math. The liquid chlorine strength is an estimate, and you only know exactly how many ppm you’ve added once you test.
Good job on finding the computer glitch, by the way. Looking forward to better results soon!
I know what you mean about having a sunny day to test CYA. They’ve been few and far between since Labor Day. I’ve run my last couple of tests in the laundry room since it’s the lighting that gave me similar results to the sun back when we had that. When the sun returns you might run a CYA test outside and then just reuse the same sample to find a place in your house that produces similar results. It seems kind of like overkill, but I get the sense that you might like overkill, and it has been reassuring to me to have an indoor test spot to see what over 2 feet of rain has done to my pool chemistry. (In my case it was good because it brought my CH down.)
