Just had my pump replaced with the intellipro VSF and had intellichlor IC 40 installed. It seems they installed it so that the SWG is always on whenever the pump is on. They wired it to the load side of the pump is what they said. Is that correct?
I was only planning to have the SWG run for about 10 hrs a day based on the chlorine I need it to produce is about 2.5ppm day. What speed will I have to run the pump in order to get enough flow for the SWG to operate or does it not matter? I have a robot cleaner so only need to run the pump at higher speeds for the SWG if necessary.
