Hi TFP Gurus
I'm looking for advice on my IC40 - I've read some of the threads in this part of the forum and edumakated myself a bit, but have some specific "advice to me" questions that I'd love to get some opinions on from folks who've been there and done that!
Background:
Previous owner put in pool 12 years ago. We moved in 4 years ago and converted to salt. Installed this IC40 at that time. Cell is 4 years old.
Have just completed re plaster and pump replacement. about 5 weeks ago. IC40 was NOT replaced as part of this upgrade.
I'm 5 weeks in from that being finished and, with awesome support from Jim R, have worked through some initial VariSpeed/Automation/EasyTouch issues.
As part of that troubleshooting we identified that the IC40 seems to have some issues:
For full disclosure - I've done no maintenance on the cell. Ever. My bad. :ncool:
The IC40 is producing chlorine at levels I would expect based on past years operation.
My numbers are fine, I think:
Meh! Maybe TA is a little high but this is a new start and it will come down with the amount of acid I'll end up adding over the next few weeks.
I'm testing the salt level with the Taylor K1766 (Silver Nitrate) test kit. I'm backing that reading over the SWCG reading as it's been consistently more reliable over the years and, at this point, I started with a fresh fill (NACL ~100ppm - tested) and added 560lbs of salt to a 27,000 gal pool... 2600 makes way more sense than 4700!
All other tests are with the TF-100 kit (of course!)
Questions:
Thanks in advance all.
Cheers
MattJ
Background:
- The flow light is ALWAYS on when IC40 is powered. Even when pump is not running.
- IC40 salt level reading is constanly 4700 when I am sure my salt level is 2600 +/-
Temp: 86F - love me some North TX summers :sunny:
pH: 7.6
FC: 2.5
CC: 0
TC: 2.5
CH: 250
CYA: 50
TA: 130
NACL: 2600
pH: 7.6
FC: 2.5
CC: 0
TC: 2.5
CH: 250
CYA: 50
TA: 130
NACL: 2600
Questions:
- At 4 years old, how far through the cell's expected life am I? I get there are probably many variables in play here (including no user maintenance!) but I have no idea if this thing should last me for 2 years or 10 years.
- I'm pretty sure the flow switch is broken. Is it worth taking the cell out of the system to see if it's just "stuck" mechanically or chemically (corroded) and can be fixed?
- If the flow switch cannot be fixed and the cell has life in it... is it worth doing a replacement on the flow switch? It looks like you can get both Pentair and OEM replacements.
- Jim R said that a faulty flow switch is a potential safety issue. I have no reason to doubt Jim at all - he helped my out a bunch - but how bad is it?
- I read on another thread that local pool stores will test the cell. As I'm pretty sure my cell is generating chlorine and equally sure my flow switch is toast... would there be any additional info to be gained from getting it tested?
- I read on another thread that a faulty flow switch can cause erroneous NACL readings. True? If that's the case then I'm going to tackle my "flow" issues first.
- If I have this thing apart... is it worth actually doing some maintenance and acid washing it?
Cheers
MattJ
