I know this is not the focus of this message board, but I am curious if anyone here has any experience with natural pools, where you use a system with plants to clean and filter the water. I am just starting to think about this.
What is the point of a natural pool? What is the reason to want a pool that is not sanitary and you hope the natural filtration keeps it clear and safe to swim in? How do you check to assure that the water is safe to swim in?
If you take proper care of a chlorine pool it is clear, safe, comfortable, and easy to care for. What is missing from that equation that a "natural pool" brings to a table?
Chem geek does have posts on this and how to mantain one, it is a lot harder and because of that a lot more unsafe than our easy clorine pools.
If you come back I'll try to find it
Doesn't water temperature play a part, too? Aren't all those horrible nasties worse in warmer water, or do water plants counteract that somehow? Are the 'successful' natural pools in much cooler climates? (but then who wants to swim in 65 degree water?)
I know there have been reports of fishermen or swimmers getting flesh eating bacteria in the warm shallow waters of the Gulf near Houston. Not many cases, but I don't care how few cases. I don't want to risk that.
When it comes to water, what is good for you and what is good for a frog are not the same. Most of the ideas behind a natural pool are somewhat sound, though in practice pulling them off properly is far from a sure thing. And with no easy way to measure whether you have successfully created a safe swimming environment it is not something I would recommend to anybody I know.Probably a frog pond separate from the swimming pool would be a better idea.
It'll be interesting to see if the frogs allow you a say in which pool they'll use!!![]()
