One more question, your gauge. Does it go down to zero when you turn the pump off?
Yes it does.
Been busy for the past few days. The extra sand seems to be helping, I THINK if might be a tad too much as I'm seeing quite a bit of sand in the glass vial attached to the valve than I did before.
I finally received my vacuum equipment and vacuumed last night and this morning. Vacuumed to waste yesterday, tried to be quick, but still lost a lot of water. We've had some rather bright and hot (100*) days lately and I think that's making it more difficult. I've been adding water almost daily.
A few things.
I'm really surprised at how much chlorine I'm still having to add each day (approx 2 gal most days). I'm trying to keep the FC around 10.
Which brings me to my second point...CYA...Why can't I get my CYA up? Is it because I keep having to add water due to the frequent backwashing and Hades like heat we've had lately?
I have added a total of 8lbs. 2lbs was added to the skimmer (my fault, didn't know better) so I assume that probably got backwashed out, and the sand was changed since then, so lets call it 6lbs. 4lbs of the 6lbs was added by slowely sprinkling it directly in the pool around its edges. The final 2lbs was put in using the sock method over the course of 2-3 days. It was just empty yesterday around noon. I just checked it tonight, and I'm still estimating around 20 or so as it JUST starts to get really cloudy in my test kit around 30, which is its minimum threshold.
When I tested my FC today and it was low again this evening, I thought for sure maybe a component of that was that the CYA was finally rising some, but that doesn't appear so.
On the upside, the pool is clearing up. There was a good amound of flaky white stuff that I had brushed off the walls and vacuumed up and I can now see the silhouette of the robot on the bottom of the pool, but its still foggy.
At this point I don't know that I'll have it ready by the Fourth of July, which was my wife's plan to have a nice party at the new house.
Anything I'm doing wrong or just more of the same?
Am I not understanding something in regard to the CYA/FC relationship? I've read a bunch already, but I'm willing to learn.
Thanks again!
