I am in the process of opening the pool for the season.
I added the 6.5 pounds of de via the skimmer to the filter.
The filter worked fine for e few minutes and than the flow became very low to a point where I had to turn off the pump.
After several attempts with same results, I opened the filter to find out that the powder did not stick to the fingers but was all in the bottom of the filter tank.
Also the valve shows high pressure of 26-30
Do I need a new filter or are there other issues?
