Hello all, I am a first time pool owner. We have an above ground Intex 18x48 that came with a pump filter but I also have a used Intex CS8111 SWG ( along with all the hoses and other parts) that was left from when my in-laws had a pool many years ago. The pump itself and the hoses have been stored un-covered in the garage since then. The o-rings are all shot so they will need replaced and the pump will need a good cleaning in a general way but are there other things I should be concerned about? Is the pump no good at this point?
Also, if I initially set up the pool with the factory pool pump can I easily change it over to the SWG once I get it refurbished later on?
Thanks!
Thanks!
