We bought our house last year and the pool was practically open and I was able to maintain it with TFPC method. I don't think I closed it correctly last fall but I can't go back. We took the cover off this morning to this.. Everything is settled to the bottom and I'm not sure what we should do first because I don't want to stir it all up if I don't have to. I have tested the water using the TF-100 and I'll list the numbers at the end. I'm not sure if we need to brush it, vacuum it, hook up the pump, pour bleach... I'm unsure of the order of things and am hoping I can get some guidance. I know that since my CYA is at 0 that I'll need to get that bumped up before SLAM-ing.
Thank you!
Water test:
FC- 0.5
pH- 7.3
TA- 60
CYA- 0
Thank you!
Water test:
FC- 0.5
pH- 7.3
TA- 60
CYA- 0
