Haven’t SLAM yet...just adding bleach until FC holds at 5 . Just trying to get rid of ammonia. Hopefully I can SLAM soon. My understanding is once I get the correct reagents continue to make sure I have gotten rid of ammonia , then can up my CYA , adjust pH ,( looks like it is at 7.2 )and begin SLAM . Do I have that right? Again , all my thanks!
Oops, I jumped the gun there! =) yes you've got it right! Suggestion (using PoolMath) once your FC is 5+ after 30-60min, I would aim for a stabilizer level of CYA/20~30, so as not to overshoot (a goal of 30) and increase the FC requirements
You should get through a SLAM Process pretty quick since you have 1 of the 3 criteria met, "clear" water =)
Are you sourcing a FAS-DPD test? That will be needed to properly measure FC & CC during the SLAM.
