I have recently moved into house with a pool and the previous owner did say that the pool had not been opened in about 2 or 3 years. I have never owned a house with a pool so pools are all new to me.
We just recently had the pool opened and the company that we had open it was trouble shooting the heater to get it to start up. After hours of working on it the technician stated that it needed a new pilot light. I received the estimated invoice for the replacement of the pilot light and it had and hour to replace the pilot light ( that a lot of time to removed two screws and unscrew a gas hose). The technicians returned a few days later to finish checking the pool chemicals (that is another horrible experience with them) and install a new pilot light assembly which had a new thermopile. TWO HOURS later he had the pilot light assembly installed (the slowest worker I have ever seen) but he could not get the burners to come on with out jumping the terminals. He said it needed a new pressure switch and limiter switches. He returned a few days later and 30 minutes into working on the heater he just gave up on working on it and left and did not even attempt to install the new parts.
After reading the manual and researching on the internet I decided to try to fix it myself. First I went through the heater and gave it a good cleaning to get all the stuff out of it and cleaned all of the corrosion off all of the connectors and checked continuity between all the wires to verify that the wires are all good, which they were. After about 15 minutes of holding the gas control knob down and turning it to the on position, I was able to get the pilot light to stay lit. The burners would not come on so I jumped the TH terminals and got the burners to come on. When I removed the jumper the burners would stay lit for a moment or turn off if I turned down the temperature switch. After about 20 minutes the pilot light went out and I could not get it to stay lit. I have held the gas control knob down for up to 5 minutes and measure the thermoplie output and was getting over 500 millivolts. I have attempted this multiple times and got the same results. I have followed the flow chart in the manual and verified that the thermoplie is engulfed by the pilot flame, checked that nothing was blocking the pilot light, and removed both TH wires and attempted to relight the pilot. It would light up but wont stay lit. The next step is to check the thermopile, if below 400mV replace thermopile, if above 500mV it says replace the gas valve. It is reading above 500mV, but I have read on the internet that is even better if a reading is that high. The thermopile is new and getting good readings. But before I pull the trigger of a new gas valve, I wanted to get another opinion from people who have more experience with pool heaters and see if replacing the gas valve is the next correct step to getting the pilot light to stay lit.
I do realize that once I get the pilot light problem fixed that I have another problem of getting the burners to work properly.
Sorry for the long post but I just wanted to state everything that had been done to the heater so far.
Thanks
Thanks
