How about an updated complete set of test results from your TF-100 - and by that I mean all new results, not those from a few days ago. Include the water temp also.
Have you been keeping on top of bleach dosing? what FC numbers are you targeting?
FC
CC
TA
CH
CYA
Salt
Temp
With those in hand, we can better advise on additional steps.
Outdoors gal you don't want to add any more cya if you're at 45 or 50 now. If you add any more cya CONDITIONER you'll go lower and then you will have to drain your pool some more.pH 7.9
FC 4.5
cc .5
ch 275
TA 120
cya 45 (round up to 50 but i kept at 45 in pool math for more exact readings)
80 degrees
salt 2400
csi .18
i have some theories in playing around with #s in trying to keep csi at 0 but i have to run so i wanted to at least get this out there. it's very different having low CH. Not so sure i need to get TA or and pH down so much now?! turned back on the bubbler for now just in case but I'm not sure if it's a rush to lower TA now? interesting and I look forward to hearing if there's one way to do this or more. In pool math there's more than one way to get csi to zero. thx!
Did you test your fill water for the salt content? I have 400 parts per million salt content in my fill water so when I got the 2600 I checked and started my saltwater generator on 0% just to see if the saltwater generator showed green light for the salt content. It had a solid green light showing enough salt content so I figured that over the summer with the evaporation and such with the 400 parts per million on fill water the salts going to go up anyway.
I also try to keep my pH as close to 7.2 7.4 as possible so you get less calcium buildup. In the swg as well as the pool walls and tile. Over and out trapperman
Only if you're refilling with salt water....either that or I don't understand what you mean. Do you have the recommended K-1766 Taylor salt test kit?As water evaporates salt will be added to the pool by refill water and then I"ll end up with too much salt.
Got brick red at 17. salmonish at 15. i'm going with 17 cuz that was the darkest color.
OP has a SWG - CYA needs to be higher than for a non-SWG pool. See the bottom half of this chart: [FC/CYA][/FC/CYA]
Also, the focus needs to be on CSI rather than just pushing pH to 7.2-7.4 -- having too low a pH could cause calcium to leach from the plaster. Keeping the CSI between 0 and -0.30 will help keep any scaling to a minimum.
If you are more comfortable with salt at 2700 - try it and see if the SWG will generate correctly. No harm in trying.
As for the CYA - with a SWG, the recommendation is 70-80. This helps prevent the FC from burning off so quick in our intense sun and heat. The SWG produces a small amount of FC for the time it is operational. This is in comparision to adding FC manually, where you add a bunch (relative to how a SWG adds FC). And if I recall, you are on SRP Time of Use - so probably have the pump off (no generation of FC by SWG) during peak times.
You can spend 5 minutes a day on the pool (in summer, less in winter) and enjoy a trouble free pool - or hours and hours over days/weeks trying to recover from a green swamp numerous times during the year (extra cost, time amd frustration).
You've been here almost 3 years. You know the TFP recommendations and how to test. And remember -- it's your pool- you are free to maintain it however you wish.
Oh yeah - would have probably been better to post this to your original thread so others could easily follow the story.
EDIT: Thanks to our crack moderating staff for merging your 2 posts!
odg,
I find that I can start tasting the salt when it gets over 3400 or so... My SWCG needs at least 2800 to run, so I like to have my salt between 3000 or 3200.. The cell does not make any more or less chlorine as long as you are within the manufacturer's recommended salt levels.. You can use whatever level works for you...
Same with the CYA... If you leave your CYA at 50 you will just have to turn your cell's percentage of output up, because the sun will burn off your FC quicker.. I still suggest that you increase your CYA to 70 or 80, but there is no harm in trying it at 50 and seeing what happens..
Keep in mind that you never what your FC to drop below 3 ppm, so it is better to run a little high, rather then right at the target FC... I use the target level as my minimum just to make sure..
Jim R.
Once you get your pool figured out, it's so easy
outdoorsgal,
I noticed something a few posts back. You're testing salt with the new kit the way I used to before joyfulnoise taught me the correct way. You don't keep counting drops until the color is as deep as it gets, like you do for TA or CH. The salt test is over once the first drop changes the color of the water permanently "salmonish." Not when you see it flash salmon and then go back to milky, but when it first stays "salmonish." The dark red brick color is too far. So in your example above, the test result is 15, not 17. Have another look at the kit's directions, and you'll find it says just that.
Good luck with your pool. Keep testing everyday for a while, and posting the results here each time, so the TFP experts can continue to help you.
