I have a StaRite filter that leaks through the backwash line even when not on backwash. I have been trying to research and it sounds like I need to replace the spider gasket. I looked up the number on the top of the filter - StaRite 53185. I found the following replacement parts Parts For Sta-Rite Top Mount Valve Parts - Pentair Multiport - Swimming Pool Valve Parts. It does not seem like there is a spider gasket in that valve, just an o-ring... Is there anything else I should be replacing? Will replacing the o-ring fix the problem?
I'd appreciate any help or advice you can offer! I just bought the house last year and this is my first pool project other than figuring out how to close the pool.
