From your mouth to God's ears! Will do and will keep my fingers crossed.
Thanks and have a good night.
No need to wake up in the middle of the night. I think we would all go nuts if we had to do that. ha. In the beginning of the SLAM, I'd check the FC about an hour after reaching SLAM level (12). Then if it holds fairly well, add bleach and check in about 2 hours, then next time maybe extend to 3 hrs if it's holding well. Eventually you'll see a pattern where the water retains FC better & better until it drops very little throughout the day. That's when you know you're getting close and ready to try another overnight (OCLT) test.So, how often should I test FC moving forward and adjust? Every 2 hrs, 4 rs, etc?
We did some extensive testing on this. The results were once dissolved, you can consider your CYA at the predicted target within the next 24 hrs or so. It doesn't take a full week as previously thought. I think that was related to granules that may be stuck in a filter by mistake.How long after you have squeezed all the contents of CYA from the sock and into a cloud of dust in the pool water, will it take to distribute in the water to get an accurate reading?
I'm confused by the statement though. Needle? The CYA test has no needle and shouldn't impact your filter PSI gauge, so you'll have to help explain to me what you mean on that one.I have been circulating the water for several hours after I added another 1/2 cup of CYA, and does not seem to have moved the needle much.
You should see a change. But if not, you can feel comfortable adding stabilizer in increments of about 1 cup (about 7 ppm of CYA), or maybe 1.5 cups at most (10 ppm of CYA). Not sure if I passed this along before, but here's my little CYA testing reminder if you need it:Hopefully the CYA will be there tomorrow.
Proper lighting is critical for the CYA test, so you want to test for CYA outside on a bright sunny day. Taylor recommends standing outside with your back to the sun and the view tube in the shade of your body. Use the mixing bottle to combine/gently mix the required amounts of pool water and R-0013 reagent, let sit for 30 seconds, then gently mix again. Then, while holding the skinny tube with the black dot at waist level, begin squirting the mixed solution into the skinny tube. Watch the black dot until it completely disappears. Once it disappears, record the CYA reading. After the first test, you can pour the mixed solution from the skinny view tube back to the mixing bottle, shake, and do the same test a second, third, or fourth time to instill consistency in your technique, become more comfortable with the testing, and validate the CYA reading.
