With pool season around the corner I want to preorder water chemistry supplies.
I'm planning on starting with the following for my 34,500 gallon pool based on poolmath and usage history.
What/how much do you stock?
Complete water test kit
Bleach 10 jugs (use until water is warm enough for SWG)
Muriatic Acid 4 jugs (my pool eats this over the summer and it's not easy to find nearby)
Calcium 50 lbs
Stablizer 20lbs (use half at startup)
Boric Acid 80lbs
Salt ???4 bags???
If you think I'm low/high on anything here, I welcome a head's up.
Thank you!!
Calcium 50 lbs
Boric Acid 80lbs
Salt ???4 bags???
Thank you!!
