I installed a new 1.5 hp motor on a pentair challenger and it wont turn on. It doesn't make any noise like it is the capacitor or even shorting out (breaker doesn't trip). I checked voltage with it on and it is receiving voltage to connections. Time clock is giving 125 volts per wire. There is an area where supply wires come into time box that is a little corroded an wire look slightly burned up. Motor shaft is freed up. I tightened them up and seems fine. Any advice would be wonderful. Thanks
