After a month then everything here applies. You are still needing to add acid to keep pH under control. You should be able to use a robot/pool cleaner if your PB said so.
Take care.
ya my PH is always high
Take care.
I would use the magic stirrer on every test except the PH and CYA.
-FC will come down on it's own. No need to try to lower it. It is safe to swim like it is.
-PH might be higher and need to come down. Use muratic acid to lower it. Try to fine the 30% kind. Most of the time it is kept outside at Lowes by the pool stuff. Use Pool Math to see how much to add. Make sure to wear eye protection.
-TA it will be the last thing we work on. It is a process that is very easy to do as seen in this link: Pool School - Lower Total Alkalinity
-CH leave it where it is. It will not go any lower so it is good where it is now.
-CYA you do not want it any higher. We say to round up so you should call yours 50. That is a good level for a non-swg pool.
You did a great job!! Was it easy? Fun?
Kim
Then up your CYA goes!! (will you look at that............salt system right in the siggy DOH! Sorry about that )
Do you have a cute pair to socks to put it in with??
Kim
No reason to get liquid unless your rich and lazy, your neither since the rich and lazy just waste large amounts of money on pool services.
Maybe
Where can i buy solid/granular cyanuric acid???
