After a month then everything here applies. You are still needing to add acid to keep pH under control. You should be able to use a robot/pool cleaner if your PB said so.
Take care.
ya my PH is always high
Take care.
I would use the magic stirrer on every test except the PH and CYA.
-FC will come down on it's own. No need to try to lower it. It is safe to swim like it is.
-PH might be higher and need to come down. Use muratic acid to lower it. Try to fine the 30% kind. Most of the time it is kept outside at Lowes by the pool stuff. Use Pool Math to see how much to add. Make sure to wear eye protection.
-TA it will be the last thing we work on. It is a process that is very easy to do as seen in this link: Pool School - Lower Total Alkalinity
-CH leave it where it is. It will not go any lower so it is good where it is now.
-CYA you do not want it any higher. We say to round up so you should call yours 50. That is a good level for a non-swg pool.
You did a great job!! Was it easy? Fun?
Kim![]()
Then up your CYA goes!! (will you look at that............salt system right in the siggy DOH! Sorry about that)
Do you have a cute pair to socks to put it in with??
Kim![]()
No reason to get liquid unless your rich and lazy, your neither since the rich and lazy just waste large amounts of money on pool services.
Maybe
Where can i buy solid/granular cyanuric acid???
