I have to assume your happy with the VironXT
Yes - seems to be a fairly reliable and popular pump. It is a DC drive motor with an electronic speed control for the variable speed side of things.
Spares are readily available (seals, O-rings etc) - so no dramas if you have a problem.
The current Viron XT is actually a revised pump that Astral used to sell years ago. It has better performance and efficiency figures and is quieter as well.
How did you select your equipment, a mix of Waterco and Astral?
Pretty much what the majority of pool builders use here in Adelaide. A lot of the overseas products are more expensive but more importantly they tend to be more difficult to source, so many PB's use Astral products.
The Waterco multicyclone is probably the best designed cyclone device from what is on the market and my PB also recommended that one over others.
So far - everything has been working OK - I would not worry about tech support too much as there are a few of us on here at TFP that are well versed on some of these products - so any questions - just fire away...
