Results 1 to 7 of 7
Thread: Really Old Plaster Pool Challenge
    Feb 2018
    Glendale, AZ
    2
    Hi! New here. Have browsed around the site for awhile and now have decided to get some real help! I have owned pools in AZ for 25 years. The one I currently own has been 18 of those years. I believe it is original plaster and it is in horrible condition, but right now, we do not have the money to get it resurfaced so are trying to limp along for another year or 2 until we can resurface. Had a regular pool guy for a couple years when my husband was sick and it was too much for me. Even for an old pool, it is relatively trouble free most of the time. He was a common sense guy, but just no longer in the budget. He said we should probably drain and refill every year to help with maintenance. For various reasons, we have not drained and refilled for 3 years. That being said, this winter has been rough with the pool (algae even in cold weather etc) so we drained a couple days ago and have now refilled. We bought the Taylor K2006 test kit and just completed the tests. I tried putting in the results in the pool math calculator, but am confused how to interpret and about what I am seeing.
    Here are our test results: pH 7.7, 0.4 Free Chlorine, 0.4ppm combined chlorine, 130ppm TA, 0 CYA, 230 ppm Calcium hardness.
    I am just looking for help on what to buy and how much I need to get the start up going and how to effectively use the calculator. I usually use 3 in chlorine tabs (trichlor) for maintenance and either powder shock or liquid chlorine for shock. I am reading on here about household chlorine bleach and am sold on that from here forward.
    Let me know if more information is needed.
    Thanks!
    25,000Gal in ground, 34 YR old plaster, Pentair WhisperFlowHPpump, Hayward ProSeries Sand, City water
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: Really Old Plaster Pool Challenge
    Welcome to the forum!
    First you should get 3 ppm of FC by adding liquid chlorine/bleach. In your pool that is 111 oz (lets call it a full jug) of 8.25% bleach.
    Check your FC each day and add enough to keep at 3 ppm.
    You need CYA powder from Home Depot or Walmart. Start with adding 30 ppm, or 100 oz to your pool. Get enough to add at least a total of 50 ppm, or 10 lbs. You add the CYA by placing it in a sock/knee high and tieing it shut. Hang the sock from a pole in front of the pool return. It will take a few days for it to dissolve.
    Your pH is ok right now but will increase. When it gets to 8, add enough muriatic acid to lower it to 7.6. Test your pH at least twice a week.
    As you get into March, you will be adding more chlorine each day. Follow the FC/CYA Chart. At the peak of summer, you will be using about a gallon of bleach every day.
    Keep asking questions!
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,830
    87,
    Welcome to TFP... A great place to find the answers to all your old pool questions...
    Marty has you covered with his answers above, but I have a favor to ask of you... The next time you report your test data, please do so in the following format.. It really helps us when reading your posts...
    FC .4
    CC .4
    pH 7.7
    TA 130
    CH 230
    CYA 0
    Thanks for posting and keep asking questions...
    May 2014
    Laughlin, NV
    11,793
    When you test your FC - use the 10 ml sample test. You will divide the number of drops to clear by 2 for your FC. Close enough for us.
    Marty
    Feb 2018
    Glendale, AZ
    2
    That is much easier to read! Will do
    FC .4
    CC .4
    pH 7.7
    TA 130
    CH 230
    CYA 0
    Jim R.[/QUOTE]
    Thanks for adding that about using the 10ml sample test. We followed the directions to the letter and couldn't find an answer to help us choose.
    Last edited by 87Hawkeye; 02-15-2018 at 09:15 PM. Reason: reply posted on wrong post
    PoolGate's Avatar
    Jun 2017
    Damascus, MD
    2,365
    Strange that your CYA test shows 0 even though you are using the trichlor pucks. I would test again this is the hardest test to get correct results.
    29k Gallon Free Form Gunite Pool, 3 floor returns, 2 wall returns, 1 vacuum pressure port, 2 skimmers, Main drain, Jandy 2.7HP VSP, Jandy JXI400N Gas Heater, Jandy CV340 Cartridge Filter, FusionSoft 1400 SWG, 2 Watercolors LED, iAqualink with PDA, Sheer Waterfall, Rock Waterfall, 9' Deep End w/Diving Board, SunDeck, Polaris 9650iQ, TF-100 - Pool Build - 2017 - Google Photos
    triptyx's Avatar
    Apr 2016
    1,485
    Quote Originally Posted by PoolGate View Post
    On a fresh fill, with zero CYA starting point, pucks will take a while to get CYA up to around 20ppm where it will start to reliably register on the test. When your CYA is very low, pucks take too long to get it up, so the poster will need to use granulated CYA to get it up to near range in a timely manner.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
