Thread: Main drain leak?
    Feb 2018
    BOYNTON BEACH
    1
    Main drain leak?
    I have an inground cement/diamond bright pool
    Over 6 mos, the pool has gone dry.
    (I stopped adding water) and stopped running the pump.
    Since it leaked/evaporated all the way dry, my guess is a main drain leak.
    Before I spend $300 on leak detection co, what can I do to isolate the problem?
    Thanks, Bob
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: Main drain leak?
    Welcome to the forum!
    Can you put what State, Country, or Province 'Boynton Beach' is in?
    As your pool is drained, you can plug the main drain outlet in the pool and then pressure test were the line comes to your equipment pad.
    If you are in an area that gets much rain or you have a shallow water table, you are in grave danger of the pool popping out of the ground. That is catastrophic. It would be best to get the pool filled with water ASAP.
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
