You need to get familiar with the FC/cya chart. This chart is like the pool bible, I dare say the most important single piece of info in all of pool school.
From previous posts It looks like your cya is 90, in which case you should never go below 7 FC (per the FC/cya chart [emoji6]) so even if your water was perfect, 5 is too low. And during daily testing and bleach additions you should target 10-12. Reading through the posts it sounds like your loosing quite a bit of chlorine, more than the normal daily 2-4 loss that all pools have. So you probably need to slam. You can go ahead and do the oclt tonight to confirm but my gut is telling me a slam is in order.
If you decide to slam the target level with a cya of 90 is 35 FC (per the FC/cya chart) which is doable but really high!! So the first decision is whether to drain about 30% of the water to get cya down to a more manageable level or slam at 90 cya. This is your choice, the trade off is cost of water vs cost of chlorine.
Hopefully that helps clear some things up, keep reading pool school and ask questions. And keep the FC up per the chart.
