I’m back for some advice from the experienced TFP pool experts. Looking now for a series of "practical steps” to help me get better control over various pool chemistry issues I face upon opening my pool. The traditional sequence of pool opening procedures may or may not be the best steps for a pool owner like me with several factors in-play all at once. Interested in your suggestions/opinions. I need to feel reassured about what to do when -- and in what order.
My related post (2014): STARTUP is a bigger and bigger challenge with each new season -- any ideas why? Still available for reading in TFP FORUM.
The pool chemistry problems I’m juggling this Spring:
No CYA when pool is first measured in spring – happened last 4 yrs.
Evidence of ammonia residue – CC high – rapid loss of FC. Suspect bacteria.
When first uncovered my pool had a “slightly green” hue but clear. This turned into a full algae bloom
requiring a week or longer to kill & clear.
High amounts of iron and calcium in local city water (need dose of sequestrant)
PH (+) and ALK (-) needed adjustment too.
VERY High Phosphate levels (3000+) – 1st time this year in 30yrs.
My pool person with years of experience and lots of industry training, wants me to follow these steps to OPEN. I should do nothing at first after opening except to circulate the water for 24-48hrs. Then take readings. Next add a dose of metal sequestrant and wait 48-72hrs. Next add a POLY algecide adjust PH/ALK. Use a PHOS remover (necessary this yr) which requires another 48hrs. Finally introduce liquid chlorine (10%) or dissolved Cal Hypo. By the time I got around to the chlorine shock addition, however, I had a full outbreak of algae. CYA needs to be added sometime too to raise it 30-50ppb – but supposedly only after the algae is killed and filtered. I suspect it is not the BEST sequence to follow for my situation. Like to avoid the algae bloom and try to clean up the bacteria debris earlier. Just not sure what to do when all these are in play.
When it comes to CLOSING, I’ve assembled several suggestions from various on-line sources they say are likely to improve my odds for an easier opening. Do these make sense?
Lower CYA levels by drain/refill to 60ppb or lower. Anything higher will make getting rid of CYA debris from the bacteria eating the CYA over winter. The more CYA the bacteria has to eat the more debris to clean-up with tons of chlorine.
Wait until late Fall to close – water below 60-degrees. One said early Nov but there would be tons of leaves in my pool unless I run the pool covered.
Shock pool and wait a little for levels to come down some. Add “heavy” dose of Poly 60 algecide. Add a full dose of metal sequestrant.
Dissolve cal-hypo shock in warm water and pour into pool 2-3 times – weather permitting.
Use a pool pillow to keep cover off of water surface – also allow escape opening of some kind for ammonia gasses?
Open EARLY in spring – maybe late March/ early April. Water is usually still very cold.
Appreciate any feedback you can send my way.
Tom
Tom
