Hello everyone,
First I just want to say thank you to all of those who make this site possible. It's a goldmine of information for newbies like me. I've been doing a lot of research in an effort to learn how to maintain my first pool. My natural inclination would be to follow the recommendations of the pool industry (APSP). Even though Trouble Free Pools doesn't always conform to industry standards, you guys seem to know what you're talking about so I've decided to follow your recommendations. Besides, the TFP standards come with free advice!
So, I removed my mesh cover and found a green and filty pool. I spent the first few days brushing and vacuuming while waiting for my kit to arrive. The kit finally arrived and I took my first readings. Here's what I got:
TA 50
pH > 8.0
CH 140
CYA < 30
FC 0
CC 0
Salt 2200
I then took a water sample to the pool store to be double checked. Here's what they found:
TA 48
pH 8.4
CH 108
CYA 24
FC .09
CC 0
TC .09
Salt 2200
Copper 0
Iron .1
They used an electronic tester. I don't know the make or model. But it looks like our figures agree pretty well. They were able to get exact values for pH and CYA that exceeded the range of my kit (K-2006). They also got an exact reading on FC that exceeded the resolution of my kit. The biggest difference is CH. They got 108 and I got 140. Either way, it's a good number that doesn't need adjustment.
So, on to the next step. Info I found on Hayward.com says to proceed in the following order:
Salt -> CYA -> TA -> CH -> pH. Once that's done you can SLAM.
On this website, the article "Water Balance for SWGs" is almost exactly the same. It reverses the pH and CH steps. However, the pool store recommended this order:
ph -> TA -> CH -> SuperChlorinate -> CYA -> Salt.
Honestly, I'd rather deal with the salt last. Salt doesn't seem to be the priority at the moment. My pool is green and getting greener everyday. I need to get chlorine in it ASAP. Also, they recommend sweeping to insure that the salt doesn't settle on the bottom. That's fine but I can't even see the bottom! In regard to CYA, it is my intention to set it to 70 per TFP recommendations (70-80). If I do that prior to slamming I'll need a lot more chlorine. I purchased 7 gallons of 12.5% in preparation for that. But now I'm thinking I should slam at the current CYA level thereby requiring less chlorine and then adjust the level afterwards. So I came up with my own order that looks like this:
TA -> pH -> SLAM -> CYA -> Salt. No changes to CH.
That way I can slam just as soon as I get TA and pH set without wasting time on the other stuff. So here's what I've done. I added 9 lbs of alkalinity increaser (sodium hydrogen carbonate). I tested the next morning and TA had increased from 50 to 70 as per TFP recommendations (60-80). I'm now working on pH. My acid demand was 2 drops which means 55 oz. of muriatic acid in a 30K pool. However, PoolMath indicated 44 oz. to lower the pH from 8.4 to 7.5 with TA at 70. I decided to split the difference and go with 50 ounces. But I actually ended up adding 48 oz. just because that was a convenient mark on my measuring cup. I waited 8 hours and retested. There was no change to TA, pH, or acid demand. I let it run overnight and retested in the morning. TA was still 70. pH now looked like 8.0 and acid demand was 1 drop. I was wishing I had added the 55 oz indicated by the acid demand instead of fudging the numbers to 48. After 24 hours I still had a 1 drop acid demand so I added another 30 oz of muriatic acid. I tested about 6 hours later but no change yet. I'll probably have to run it overnight again and hopefully see a change in the morning. I hope I haven't over done it.
So that's where I'm at right now. I've got a green pool and I'm waiting for pH to get into the proper range before I slam. I would love to hear your thoughts on all this.
Am I doing this correctly?
Can I follow this order: TA -> pH -> SLAM -> CYA -> Salt. No changes to CH ?
Should it take this long to see changes in pH?
What's the quickest and best way to get TA and pH set while avoiding the yo-yo effect?
Sorry this first post is so long winded but there are so many nitty-gritty details and a million questions!
Swish
TA 50
pH > 8.0
CH 140
CYA < 30
FC 0
CC 0
Salt 2200
TA 48
pH 8.4
CH 108
CYA 24
FC .09
CC 0
TC .09
Salt 2200
Copper 0
Iron .1
Swish
